file Configuring plugin for Jquery & Mootool conflicts
9 years 3 days ago #4641 by karencox01
Replied by karencox01 on topic Configuring plugin for Jquery & Mootool conflicts
Hello I sent the logins to you. Let me know if you received them alright.
9 years 3 days ago #4642 by syw
Hello Karen,
no, I have not received anything yet. Could you try and send them again? Thank you.
9 years 2 days ago #4643 by karencox01
You should have received it as I have double checked and your email address was entered correctly.
I have sent it again.
9 years 2 days ago #4644 by karencox01
Just sent an email over let me know if you receive it.
9 years 2 days ago #4645 by syw
Ok, got it this time, thanks!
9 years 2 days ago #4646 by syw
I have actually found out that the plugin has no effect on your pages for the simple reason that there is a ~ in the site paths.
The regular expressions do not take into account that special character.
I have just double-checked the validity of this character into URLs, and although rarely used (I personally never came across such a case), it should be considered by the plugin.
I will make the proper modifications to the regular expressions of the plugin and check it on your site.
