file protocol https
9 years 7 months ago #4484 by french150
protocol https was created by french150
Do your component work fine with the protocol https? Something to set?
Best regards
9 years 7 months ago - 9 years 7 months ago #4485 by syw
Replied by syw on topic protocol https
yes it does work with https.
It can actually work also without protocol.
Check www.simplifyyourweb.com/documentation/jquery-easy/basic-options (go to the section 'all libraries').
Last edit: 9 years 7 months ago by syw.
The following user(s) said Thank You: french150
