file striping java script embedded jquery library
14 years 4 days ago #301 by drcobar
I think I must be doing something wrong. I can not get the remaining j query libraries to strip from the head tag, Here is the code I am using.,,
/cache/template/gzip.php?jQuery-9a0c9f3b.js
/cache/template/gzip.php?jquery.tools.min-cfc7d7d2.js
/cache/template/gzip.php?jquery.gmap-f0e255dc.js
/cache/template/gzip.php?jquery-9dc20be4.js
They are still there when I view my cource.
My website is www.themckinneyrealtor.com
14 years 4 days ago #303 by admin
I agree you need to get rid of jQuery-9a0c9f3b.js and jquery-9dc20be4.js but you cannot get rid of the other 2. Or else some of your extensions won't work!
Did you enter the paths into the 'remaining script' field in the plugin?
14 years 4 days ago #305 by drcobar
Thank You for rapid response. I took the other two out as suggested and sent you pngs of the resulting code. I think I am doing it correctly, but they are still there.
14 years 3 days ago #321 by drcobar
I am wondering if you had a chance to look at the code I clipped and tell me if I have made some mistake. So far I still have the j query conflicts and when I enable jqueryeasy it shuts down my JCE editor (and does not strip those funky disguised scripts)
14 years 3 days ago #322 by admin
I am sorry, I took a look at it indeed and posted my answer yesterday but I must have closed the forum without submitting my answer... Sorry for this...
Basically, I do not really understand what is going on since it seems like everything is set up right. I have tried to reproduce the problem on my test sites but everything works fine, all my scripts are stripped.
- make sure you have a newline only between the 2 lines (seems like you have according to the pic)
- try to remove just one of the 2 lines and see if it works
- try to remove some other script that is not template related and see if it works (I wonder if the template overrides any changes)
- my plugin has order 0 in the list of plugins
I am not sure what else to suggest...
14 years 3 days ago #324 by admin
BTW are you using the latest version of the plugin? It should be v1.1.1...
