exclamation-circle jquery.min.js not loading in https
12 years 5 months ago #1917 by theoni
jquery.min.js not loading in https was created by theoni
We just turned our site to https (we use joomla 2.5.9, jquery easy latest version) but ajax.googleapis.com/ajax/libs/jquery/1.8/jquery.min.js does not load....
jquery.min.js only loads in http.
How can I resolve this???
I would appreciate a prompt reply, as it is a production environment.
Thank you in advance,
Theoni
PS: I found this:
stackoverflow.com/questions/547384/where...rom-google-jsapi-cdn
but how can I use it in the plugin??
12 years 5 months ago #1921 by admin
Replied by admin on topic Re: jquery.min.js not loading in https
you should be able to call the jQuery libraries through the plugin (selecting 'https'). If it does not load, this may be another issue. Could you please give the URL of the site so I can take a look? Thank you.
12 years 5 months ago #1924 by theoni
Replied by theoni on topic Re: jquery.min.js not loading in https
Here is the url: portal.c-gaia.gr/j258
12 years 5 months ago - 12 years 5 months ago #1928 by admin
I am not sure I understand what is the problem, the library is loading just fine... Is jQuery Easy enabled at this time?
Last edit: 12 years 5 months ago by admin.
12 years 5 months ago #1929 by theoni
Yes, it is...I don' t see it fine..When I see the network from inspect element in chrome, I see error in loading ajax.googleapis.com/ajax/libs/jquery/1.8/jquery.min.js.
It is loaded just fine in http.
12 years 5 months ago #1930 by admin
When I go to your site in Firefox, there is no error, the jQuery code works fine and I am able to get to the jQuery library through your source code. Other than errors you have loading fonts, I do not see any issue here. If you add a problem loading the library, you would get problems with the jQuery extensions, which you don't have...
