file How to setup jQuery Easy in case of multiple ver.
13 years 1 month ago #1854 by kaz78
I use Joomla 3.0.3 which apparently currently uses jQuery 1.8.2.
I use Widgetkit by YooTheme which apparently currently uses jQuery 1.9.1.
And I use MijoShop by MijoSoft which apparently currently uses jQuery 1.7.2.
What do I need to enter/select in Joomla's Plug-in Manager -> System - jQuery Easy -> Basic Site Options in this case?
13 years 1 month ago #1855 by kaz78
Replied by kaz78 on topic 3+ Versions of jQuery
I am not very familiar with the different versions of jQuery, but after asking around, it appears that my website 78global.com is using at least 3 different versions of jQuery:
Joomla 3.0.3 -> jQuery 1.8.2
Widgetkit -> jQuery 1.9.1
MijoShop 1.5.1 -> jQuery 1.7.2
I have installed jQuery Easy, but how do I need to set jQuery Easy up (having 3 different versions)...
My test site is at 78global.com
13 years 1 month ago #1859 by admin
you need to find out what version of jQuery will work for all of them. A good bet would be that they will all work with jQuery 1.8 (1.9 is brand new and I don't expect the folks at YooTheme to have used any specific 1.9 feature in their template). You will have to check for MijoShop though.
