file Help! Multiple Jquery conflicts how to solve?
12 years 8 months ago #1437 by phal
Whenever I install Virtuemart 2, JCE, joomla 2.5 plus any newer Yootheme running their wrap 6, I end up having multiple jquery conflicts in both the front and backend. The problem is worse in the admin area, in the theme config page whenever I save it will break the site in the frontend, with no changes saved.
I have tried many hours with jQuery Easy but seems no success. Any pointers will be much appreciated
It is a testing site www.lycohealth.com/new2
12 years 8 months ago #1438 by admin
I will look at your problem later on, I am celebrating Christmas with my family today.
Thank you for your patience.
12 years 8 months ago #1442 by admin
I have tried to check your website, but it seems offline.
12 years 8 months ago #1444 by phal
Opps sorry I mistype
it should be
www.lycohealth.com.hk/new2
12 years 8 months ago #1462 by admin
I am sorry, there is nothing I can see that looks incorrect with the link you provided me. Seems to me the frontend works as intended. Does it really?
As far as the backend is concerned, I would suggest you contact the Yootheme team, they should be there to help you out with your backend issues.
