file Help - Unsure|Lost
12 years 8 months ago #1415 by canejuiceinc
Help - Unsure|Lost was created by canejuiceinc
Good Evening,
I was directed to use this plugin to solve display issues I am having on my site.
In the Book Now option (see attachment) there should be the calenders next to the From and To input boxes they are not displaying.
www.hbkvillas.com/index.php/book-now/villa-217c
Please advise if jquery easy can resolve.
12 years 8 months ago #1418 by admin
Replied by admin on topic Re: Help - Unsure|Lost
it seems like you need MooTools for the site to work, have you set the plugin to remove MooTools? If so, please try with MooTools enabled. The calendar needs MooTools to work, apparently.
If anything, your troubles come from MooTools (and possibly conflicts between libraries needing MooTools - which the jQuery Easy plugin does not handle), not jQuery. I have checked all libraries using jQuery, and they seem to behave correctly.
