file js 404 errors
12 years 10 months ago #1213 by natselection
js 404 errors was created by natselection
Hi!
I've been trying to sort out what I think is a jquery conflict a extension is causing. So I installed your extension to try to fix it but I see these errors in firebug when the plugin is enabled:
"NetworkError: 404 Not Found - ajax.googleapis.com/ajax/libs/jqueryui/1...s/base/jquery-ui.css"
jquery-ui.css
"NetworkError: 404 Not Found - ajax.googleapis.com/ajax/libs/jqueryui/1.9/jquery-ui.js"
jquery-ui.js
12 years 10 months ago #1214 by admin
Replied by admin on topic Re: js 404 errors
Hello, there is an easy fix:
just add version '0' in the subversion field.
Google, for some reason, has no 1.9 but 1.9.0 version available at this time (there was a note of it in the download section of jQuery Easy ;-) ).
Happy fixing!
12 years 10 months ago #1215 by natselection
Replied by natselection on topic Re: js 404 errors
Leave it to me to completely miss that note. Thanks for the help!
12 years 10 months ago #1216 by admin
No problem, hope the plugin helps :-)
