file Image not properly rendered?
13 years 4 weeks ago #766 by esprit
Image not properly rendered? was created by esprit
thanks for this great plugin. I love it!
Unfortunately it seems that the image is not rendered properly. There is an empty image in the /tmp folder generated and all the settings seem to be fine. I am a little bit confused where the problem could be.
Thanks for any help.
esprit
13 years 4 weeks ago #768 by admin
Replied by admin on topic Re: Image not properly rendered?
great that you like the module!
Can you give me the URL of your website so I can see what is going on? Do you actually have an empty image or is it just that you have no image showing? Please go to the advanced options of the module and set 'show errors' to 'yes' to see if you have an error message. Thanks!
