file Calendar Image not dispalying
13 years 4 weeks ago #753 by gulam
Calendar Image not dispalying was created by gulam
I just installed this extension on my site running j2.5.6. I can see the date, title and intro text but no image. I have head type: calendar, head alignment: left, width/height: 64.
Would appreciate any assistance.
Gulam
13 years 4 weeks ago #755 by admin
Replied by admin on topic Re: Calendar Image not dispalying
I posted a fix in this thread, try it and let me know if it also fixes your issue.
Image issue thread
13 years 4 weeks ago #756 by gulam
Replied by gulam on topic Re: Calendar Image not dispalying
Thanks for your response.
I installed the version you posted in the thread but I still have the same problem. No calendar image.
webserver2.ebiz.co.tz/~sumatra
Gulam
13 years 4 weeks ago #757 by admin
Thanks for giving me the URL.
Your problem comes from the fact that the file demo-styles.css from the website's template overrides the .noimage property set in the module.
Either remove that file (if not needed) or add to the template:
.latestnewsenhanced_185 .newshead .calendar.noimage {
    display: block;
    visibility: visible;
13 years 4 weeks ago #758 by gulam
Thanks, that worked perfectly!
However, if I put a module class suffix (for eg title1) then I lose the calendar. How do I overcome that?
One other question, in the commercial version, can I have 2 news items display and then slide for 2 other news items?
13 years 4 weeks ago #759 by admin
Adding a module class suffix replaces the module id with that suffix. So if you had .latestnewsenhanced_185 before, now you have .latestnewsenhanced_title1. You have to modify your CSS accordingly.
In the commercial version, the sliding animations handle the showing of one news item at a time. More animations will be added to handle the showing of 2 or more news items at a time, but they are not available yet.
