check Latest News Enhanced - Read More Modal Not Working
6 years 3 months ago #5164 by [email protected]
Had Latest News Enhanced installed for a while and everything worked fine. Now Read More modal pop up does not work. Have re-installed, but still no good. Take a look at www.dunshaltvillage.co.uk home page.
6 years 3 months ago #5165 by syw
newest versions of LNE now use Bootstrap modals rather than MooTools modals.
Moreover, the extension now has a Bootstrap compatibility feature that allows full compatibility with the template version your site is using ('Advanced' tab).
It seems like your template loads Bootstrap packaged in Joomla (hard to tell because all scripts are optimized). Therefore make sure you set the value to 'Joomla'. You may want to empty JCHOptimize's cache as well.
simplifyyourweb.com/documentation/latest...-of-options/advanced
6 years 3 months ago #5166 by [email protected]
Thanks for the very prompt response. Have checked both suggestions but still not working. Can give you administrator access if you want to have a look.
Steve
6 years 3 months ago #5167 by syw
Ok Steve.
Please send login information to [email protected] and I will take a look.
I will need to disable JCHOptimize. It seems like you have duplicated libraries but it is hard to tell.
6 years 3 months ago #5169 by syw
The website had multiple duplicates of jQuery and Bootstrap. Thankfully, it was possible to disable all extra libraries.
