file Regenerate thumbnails
9 years 9 months ago #4603 by andrewm57
Regenerate thumbnails was created by andrewm57
www.northkitsaptrails.org/
1) I accidentally deleted some article thumbnails from the /tmp directory. How can I regenerate them?
2) I did this because RSFIrewall alerted me of unknown files in the /tmp directory.
3) why is LNE using the /tmp directory?
9 years 9 months ago #4604 by syw
Replied by syw on topic Regenerate thumbnails
If they are missing, the thumbnails are automatically regenerated. You don't have to do anything.
Moreover, you don't have to use the /tmp directory. In the advanced settings, you can choose the /images directory instead.
9 years 9 months ago #4605 by andrewm57
Replied by andrewm57 on topic Regenerate thumbnails
I don't see Advanced or a directory choice in the module settings.
9 years 9 months ago #4606 by andrewm57
Changing to /image/thumbnails/lnee worked.
However I turned off Reset pictures, cleared Cache, turned back on Reset, etc. and 3 of my 6 articles are still missing their thumbnail images.
9 years 8 months ago #4607 by syw
You didn't even have to force the reset of the pictures. When theyare missing they are automatically recreated.
If you are missing pictures it may be a different problem.
Turn error reporting on (once again in the advanced options) and see if any error is reported.
9 years 8 months ago #4608 by syw
I also went to your site and checked one news with missing thumbnail. Once I get to your article, images are missing. Therefore if images have a wrong path in the article itself, the module won't be able to create thumbnails...
