file Blurry thumbs
11 years 11 months ago #3257 by blocki
Blurry thumbs was created by blocki
Great module, but I have one issue.
The thumbs are blurry. Are there some settings to solve this, or am I missing something?
No K2 used, only Joomla, version 3.1.5.
Thanks, greetings, blocki
11 years 11 months ago #3258 by admin
Replied by admin on topic Re: Blurry thumbs
Hello Blocki,
the images are created with the PHP GD extension at highest quality. Usually the images are blurred when the originals are smaller than the images you need to show in the module. Is this the case?
11 years 11 months ago #3259 by blocki
Replied by blocki on topic Re: Blurry thumbs
Hello Oliver, thanks for your quick reply. No, the images are larger than the thumbs.(690x480)
I tried to let the module create new thumbs every time, but it doesn't help.
Greetings, blocki
11 years 11 months ago #3260 by admin
Can you send me one of the original images at [email protected]? I will try it on my test site. Add the images width and height of the thumbnails you set in the module. Is 'crop pictures' set to 'yes'?
Do you have an extension or is your template using optimized settings for images?
