file Errors with Thumbnails
14 years 1 day ago #299 by foolishsailor
Errors with Thumbnails was created by foolishsailor
Joomla 2.5
Linux Server
GD 2.0.35
See problem here:
www.foolishsailor.com/blog.html
Seems it is having issues with the thumbnails and locating files. However as you can see the thumbnails are there. Also when i look in the tmp folder there are the jpeg thumbnials there. I dont have any ideas as to the problem?
thanks
14 years 1 day ago #300 by admin
Replied by admin on topic Re: Errors with Thumbnails
as I look at it, it may be due to the fact that the picture
jackie looking doubtful.jpg has white spaces...
I am not sure the php libraries allow for that.
Can you try changing the file name and see that it actually is the problem?
Since the other images show correctly, your website is properly setup for the module to work. It is just a problem with that one image...
