file K2 Images doesn't show
12 years 2 months ago #2559 by jameslee
K2 Images doesn't show was created by jameslee
I'm working on a website and have the module installed, the images are showing when I'm using the default layout for the articles, and when I try to display k2 articles with the k2 layout, the images doesn't show at all.
I'm looking forward hearing from you asap.
Thanks and Regards,
12 years 2 months ago #2560 by admin
Replied by admin on topic Re: K2 Images doesn't show
have you tried the option 'show errors' from the advanced options? It may tell you what is wrong. Do you actually have a URL I can look at also?
The module first looks at the K2 item image. If it does not find anything, it checks the item's content. Note that until the next version (coming tomorrow) only local files are allowed. Images stored externally from your site won't show. If this is the problem, send me a direct email and I will send you the update that will be online tomorrow.
