file Images do not display
  • fitosendoza
  • fitosendoza's Avatar Topic Author
12 years 6 months ago #1785 by fitosendoza
Images do not display was created by fitosendoza
Joomla 3.0.3
Than choose Head Type image - have error
Fatal error: Class 'SYWImage' not found in Z:\home\localhost\www\econergo\modules\mod_latestnewsenhanced\helpers\helper.php on line 74
Check the name of pictures, don't help.
Site on localhost, all directory writable.
Please Help!
12 years 6 months ago #1786 by admin
Replied by admin on topic Re: Images do not display
you probably omitted to download the external library or it did not install properly. Thumbnails cannot be created because the proper helper files are missing.
12 years 5 months ago #2013 by slavi
Replied by slavi on topic Re: Images do not display
Hi, I have the same problem on shared hosting.
Joomla 2.5.
GD installed and working and allow_url_fopen is on.
Any ideas.
12 years 5 months ago #2014 by admin
Did you install the external library lib_syw?
12 years 5 months ago #2015 by slavi
My settings are:
GD Support enabled
GD Version bundled (2.0.34 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.3.11
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.2.49
WBMP Support enabled
XPM Support enabled
libXpm Version 30411
XBM Support enabled
I'm not sure that I can install other packages.
12 years 5 months ago #2016 by admin
Sorry, you did not understand.
You need to install this library on this site, like it says in the module's download page and like it did show when you installed the module :-)
