question-circle thumbnails doesn't work
14 years 2 months ago #123 by NP
thumbnails doesn't work was created by NP
I like your module, but I didn't manage to use an image as a thumbnails instead of the date.
i wrote the path of the images folder in the "Thumbnails Cache Path" parameter, then when I look at my web page it's written "error 500" and nothing works...
thanks for your answer
14 years 2 months ago #124 by admin
Replied by admin on topic Re: thumbnails doesn't work
I need more info to diagnose anything.
What is your path?
Is there a url where I can look at the problem?
Is your path writable?
Thank you.
14 years 1 month ago #127 by NP
Replied by NP on topic Re: thumbnails doesn't work
thank you for reply,
my website is: www.moltivolticapovolti.it/
the path is www.moltivolticapovolti.it/images/M_images/
should i put a specific name to the thumbnails? how the module can know which thumbnails is linked to which article?
thx
14 years 1 month ago #128 by NP
hi,
thanks for reply,
so my website is: www.moltivolticapovolti.it/, and the images/thumbnails are here: www.moltivolticapovolti.it/images/M_images
then i don't understand how the module can find the image corresponding to an specific article, should i put a specific name for images?
14 years 1 month ago #130 by admin
the thumbnails are created from taking the first image found in an article. It looks into the introtext and if no image is found, it looks through the fulltext. It is automatic, nothing has been done from your part. The thumbnails are put into the tmp directory you choose and use the article id in the name. It does not use the original image name.
The following user(s) said Thank You: NP
