file No Images are shown
13 years 6 months ago #1039 by 3runner7
No Images are shown was created by 3runner7
Hi I hope you can help me
I can't see any images? I hope you can help.
It looks like the are not created.
At first I didn't installes the PHP GD extension. but now it is and it is activated. But it doesn not work.
There are several error massages
1st Massages (actual 3) is from joomla itself
Warning: imagecreatefromjpeg(trainingmitsystem.alfahosting.org/joomla...hlon-tips/laufen.jpg) [function.imagecreatefromjpeg]: failed to open stream: no suitable wrapper could be found in /var/www/web179/html/joomla/modules/mod_latestnewsenhanced/image.php on line 27
Warning: imagecreatefromgif() [function.imagecreatefromgif]: URL file-access is disabled in the server configuration in /var/www/web179/html/joomla/modules/mod_latestnewsenhanced/image.php on line 26
Warning: imagecreatefromgif(trainingmitsystem.alfahosting.org/joomla...thlon-tips/biker.gif) [function.imagecreatefromgif]: failed to open stream: no suitable wrapper could be found in /var/www/web179/html/joomla/modules/mod_latestnewsenhanced/image.php on line 26
2nd massage for every pecture
Failure on creating image or unsupported filetype for trainingmitsystem.alfahosting.org/joomla...ingsbereiche_500.jpg
Thanks for your help
13 years 6 months ago #1041 by admin
Replied by admin on topic Re: No Images are shown
can you tell me what version of PHP you are using? What is the version of the GD library you installed? What version of Joomla! are you using? Are the GD tests in the module telling you that everything is ok?
Do you have a URL I can look at also?
13 years 6 months ago #1048 by 3runner7
Replied by 3runner7 on topic Re: No Images are shown
Hi thanks,
for answering and your help,
Here are my answers :-)
- PHP-Version(en): 5.2
The PHP GD extension is loaded
- GD Version 2.0.35
version of Joomla!
1.7.3
Is this the right module I have ?
yes it is working
But I cant find it in the module to see a test results.
Yes I did send you a personal mail with your login dates in response to your Mail. I hope you got it.
Sincerely 3runner7
13 years 6 months ago #1049 by admin
Thanks for the answers.
I will look at your site.
13 years 6 months ago #1052 by 3runner7
thanks for your help. Finally it is working perfekt.
1st thing
the URL file-access had to be enabled in the server configuration.
To change it, I hade to ask my provider.
2nd I changed the path to store the thunbnails after changing it back to the orginal file path it is working.
AND EVEN BETTER I can run dublicate the module
I'm happy :lol: and will write a review ;)
Thanks you so much.
13 years 6 months ago #1055 by admin
Great news!
And you are very welcome :-)
