file can't fix it
13 years 1 week ago #868 by flavio22
can't fix it was created by flavio22
Hi, the details just dont go on side of the picture of the contact but are listed below in a awful way
also the contacts are listed only on the left side, the theme cannot be changed.
dunno what to do
i'm using joomla 2.56
13 years 1 week ago #870 by admin
Replied by admin on topic Re: can't fix it
Hi Flavio,
this is a permission issue over the CSS files, like I explained in your email. Look at this forum's pinned posts for more explanations.
13 years 1 week ago #871 by flavio22
Replied by flavio22 on topic Re: can't fix it
hi Olivier i passed all the files under the trombinoscope exten. component and brought all to 755, sorry but all this is new for me,usually i install that's it, i'm not able to go further.
I tested the extension in local and it works, is it may be my server fault ?
13 years 1 week ago #872 by admin
You have not mentioned the permissions of the files. Have you checked the permissions of the files located in the themes folders? The permissions of the style.css.php files are the keys to solving this. And yes, it is a server issue...
