file Submit button not visible in contact form
13 years 11 months ago #429 by takaelton
The submit button is not visible in the contact form. How do l correct this? The form can only be sent after clicking enter
13 years 11 months ago #435 by admin
Trombinoscope Extended does not affect the contact form in any way. It may be a CSS problem or a template related issue. The component just calls the page. You are on a Joomla! standard contact sheet. Give me the URL of your page so I can check what is going on, but it definitely has nothing to do with Trombinoscope Extended.
13 years 11 months ago #438 by takaelton
Replied by takaelton on topic Re: Submit button not visible in contact form
Thanks for your quick response. Here is a link to the page
amazinggracewageningen.com/index.php/com...rai-maphosa?Itemid=0
13 years 11 months ago #441 by admin
Your button is there, although the image that is used as background does not load.
It is a mistake in your template.
You need to find the joomla.css file, go to line 23 and replace
.button, button, a.readon, input[type="submit"], input[type="button"], div.mobileSwitch > a, #cWindowAction .button {
    background: url("../images/dark_bg.png") no-repeat scroll 0 0 transparent;
by
    background: url("../images/style1/dark_bg.png") no-repeat scroll 0 0 transparent;
