file Field Content Not Showing On Listings Page
1 year 1 week ago #6104 by MyWorld
I created a field and add some content in the field.  The content is only showing on the details page but not on the listings page.
How can I get content to show on the listings and details page?
1 year 1 week ago #6105 by syw
can you provide more context information? For instance, are you talking about Joomla core content blog view or Latest News Enhanced blog view?
Is the field a core custom field or a third-party custom field?
1 year 1 week ago #6106 by MyWorld
Replied by MyWorld on topic Field Content Not Showing On Listings Page
It's a core custom field.
I go to Contacts > Fields > New > Create the field
Then I assign it to a category.
Please see attachment.  If this doesn't help I can provide the URL privately if that helps!
1 year 1 week ago #6107 by syw
Thanks, this helps a bit :-)
Although you are not saying if you are using Trombinoscope Contacts Pro (TCP) or the core Joomla Contact list view :-)
I will assume you are using TCP.
In the directory view, you need to go to the 'Fields' tab, 'Other fields' section. If it is a list view (or table), go to the 'Other columns' section.
Click on the + button to add a field.
In the field dropdown, you should find, under '[no group]' the field 'Other information'.
That should be it!
1 year 1 week ago #6108 by MyWorld
Hi there,
I already did that, but the information is not showing on the listings page.
I am using Trombinoscope Contacts Pro (TCP).
Please see attached.
1 year 1 week ago #6109 by syw
Ok, send me an email at [email protected] with your site credentials so I can check it out.
