check Empty fields are displayed with a non-breaking space within
2 years 7 months ago - 2 years 7 months ago #5857 by lesyeux
In a contact's details, the unfilled (and therefore empty) fields are displayed anyway, with a non-breaking space within a
<span> </span>
tag! In my opinion, they should only be rendered if they contain something. In any case, it's enough to cause appearance problems, especially when css classes are added to some fields (in my example the "highlight" class).
Last edit: 2 years 7 months ago by lesyeux. Reason: Solved
2 years 7 months ago #5858 by syw
this should not be the case if you set 'keep space' to 'No' in the 'Fields' tab.
That should remove the issue.
The following user(s) said Thank You: lesyeux
2 years 7 months ago #5859 by lesyeux
Solved!
So many parameters to know! But that's the richness of this extension.
2 years 7 months ago #5860 by lesyeux
2 years 7 months ago #5861 by syw
Merci!
