file Warning Error loading library: syw, Library not found.
2 years 7 months ago #5849 by CCANSW
After updating the Pro component this morning I am getting
"Warning Error loading library: syw, Library not found."
On the front page.
Suggestions?
2 years 7 months ago #5850 by syw
The update probably failed while upgrading the extensions library.
You may re-install the library you can download at simplifyyourweb.com/downloads/syw-extension-library.
Choose the file corresponding to your Joomla version.
2 years 7 months ago #5851 by CCANSW
Fixed. Thanks
2 years 7 months ago #5852 by syw
You are welcome!
