file Tag field empty after sorting
8 years 6 months ago #4864 by Jfranck
Tag field empty after sorting was created by Jfranck
When i sort my contacts in the backend my tags are lost.
So I use Categories but also tags to create my contact-pages.
However I have filled in the tags several times with several contact but after a while they are lost every time.
Somebody knows this issue?
8 years 6 months ago #4866 by syw
Replied by syw on topic Tag field empty after sorting
do you loose the tags when you edit contacts in the backend (in the administration console)? If so, you should report this issue to the Joomla team.
I have not noticed that issue before. What version of Joomla are you using?
8 years 6 months ago #4870 by Jfranck
Replied by Jfranck on topic Tag field empty after sorting
Olivier, Thanks for your answer
3.8, indeed, it is while working in the backend.
Just sorting them and the tags are gone.
So it could be a Joomla issue.
8 years 6 months ago #4876 by syw
It seems like it definitely is a Joomla issue, Trombinoscope Contacts Pro uses the Contacts component to get the data from.
In GitHub, I have found the same issue with articles:
Tags are lost when changing the ordering #1957
github.com/joomla/joomla-cms/issues/1957
But really old and fixed.
You definitely should submit this.
8 years 6 months ago #4878 by Jfranck
I've asked it at the joomla forum
8 years 6 months ago #4896 by syw
For your info, I have encountered the same issue with articles!
