check carousel Trombinoscope pro not showing up
8 years 1 month ago #4833 by syw
Carousels don't show if your contact items are set in %. You need to set the width in pixels (the width is set to 100% by default).
That may be what is happening here.
simplifyyourweb.com/documentation/trombi...pe-contacts/carousel
jQuery is loaded 'on demand', there is no need to install it manually, the component uses jQuery packaged with Joomla.
