file carousel Trombinoscope pro not showing up
8 years 1 month ago #4832 by SVTadmin
sadly my carousel module of Trombinoscope contact pro does not work as you can see here:
www.sv-tresenwald-machern.de/Volleyball/...out-our-company/faqs
In the first position (top to down) you can see the contact module with turned off carousel. (working)
Secon position shows the module with turned on carousel - does not work. (nothing to see)
I know that I need jquery for enabling the carousle modul but I couldn't fix it. (Where can I download the correct jquery plugin? Couldn't find a working plugin...)
Thanks for your help!
