file More contact picture issues
  • fred_zenozzograte
  • fred_zenozzograte's Avatar Topic Author
  • Offline
8 years 4 months ago #4796 by fred_zenozzograte
More contact picture issues was created by fred_zenozzograte
Another major issue just surface;
* the contact has a specific image assigned
* The image displays correctly, albeit distorted because aspect ratio is not preserved and "Process Image" seems to have no effect
* Click detail
* In the detail view the default global image displays, not the one that is assigned.
8 years 4 months ago #4800 by syw
Replied by syw on topic More contact picture issues
Which version did you update from? Did you have template overrides?
If so, your template overrides need to be manually updated to reflect changes made in the latest version of the component.
If 'process images' has no effect, it means that your page is cached and does not reflect changes you make.
  • fred_zenozzograte
  • Offline
8 years 4 months ago #4807 by fred_zenozzograte
Replied by fred_zenozzograte on topic More contact picture issues
Hi Olivier,
Caches were cleared and site caching turned off during the upgrade (been there before :-( )
I don't believe I have template overides, certainly none that I have introduced.
8 years 4 months ago #4809 by syw
Ok :-)
Send me your credentials and I will take a look at your configuration.
[email protected]
