file Icons in search not showing
10 years 11 months ago #4244 by bsbad
Icons in search not showing was created by bsbad
Hello Olivier,
the search icons for search and remove are not showing, if I enable search.
<span class="icon-search"></span>
and
<i class="icon-remove"></i>
are both empty.
Did I need to upload images or change the css?
I'm looking forward to your answer.
Ruth
10 years 11 months ago - 10 years 10 months ago #4245 by admin
Replied by admin on topic Icons in search not showing
Hello Ruth,
this is an oversight on my part, I will fix it for the next update. I have assumed the use of Bootstrap in the template, which may not be the case.
In the meantime, you can add some CSS:
.icon-search::before {
	font-family: 'SYWfont' !important;
	font-style: normal;
	font-weight: normal;
	font-variant: normal;
	text-transform: none;
	line-height: 1;
        content: "\e68f" !important;
.icon-remove::before {
	font-style: normal;
	line-height: 1;
        content: "\e7ed" !important;
This should fix it.
Last edit: 10 years 10 months ago by admin.
