file 'Name' field not showing
11 years 6 days ago #4175 by aaronfisher83
'Name' field not showing was created by aaronfisher83
I have the contacts card set up the way I want it but the Name field simply isn't showing up. This affects every contact.
If I apply a Label to the Name Field the label shows up but still not the Name.
Thank you
11 years 6 days ago #4177 by admin
Replied by admin on topic 'Name' field not showing
I cannot think of anything that would prevent the name to show, unless it is hidden in some way by a CSS property.
Could you give me the URL of the page so I can take a look at the underlying source code? Thanks!
If you want to keep the URL and possible credentials private, just send me a note at [email protected]
11 years 6 days ago #4178 by aaronfisher83
Replied by aaronfisher83 on topic 'Name' field not showing
Hi Olivier
Thank you for your reply.
I have sent an email across.
Thanks again
11 years 6 days ago - 11 years 6 days ago #4179 by admin
Thanks,
I have found the problem:
you want to show the contact in a popup window. Popup windows have, in Joomla!, a class 'modal' associated with the link. But your template states, in its CSS file, that the modal class should not show.
Therefore, add this to the CSS overrides in the menu item you created with Trombinoscope Extended:
.te_trombinoscope .fieldname .modal { display: inline; position: relative }
That should fix your issue.
Last edit: 11 years 6 days ago by admin.
