file Unable to change contact after copying module
11 years 4 months ago #3951 by Rusty320
I am using Trombinoscope v2 and am in the process of adding many modules for various contacts and categories.
When I attempt to copy an existing module in order to preserve the settings, I am unable to change the contact. Clicking on select doesn't do anything and hovering over it, I get a pulsing between the arrow and the hand. Probably a conflict, but I don't know where to start to fix this. Any Suggestions?
It was the same way in the old version and I amusing Joomla 3.3.6
Thx,
Alan
11 years 4 months ago #3952 by admin
Hello Alan,
I have tried reproducing the issue on my test site but without success. Contacts are still selectable after a copy of the module.
What I would suggest is set the server debug settings to 'development' in your adminstrator console and see if there is an error. You may have a conflict with another component but that is just a guess at this point since I don't know your environment settings.
The strange thing is that it works once for you. The duplication of a module should not change anything to the selection part. Did you try to unselect the contact first (X), save the module and then select a new contact?
The fact that the selection does not work suggests that it may be a javascript issue.
