file Misc Information Not Showing Text
11 years 3 months ago #3652 by jblaine85
Misc Information Not Showing Text was created by jblaine85
I'm using trombinoscope extended 1.5.3. I am having an issue with the miscellaneous information text not showing up. I do have the miscellaneous accordion tab showing up but when I click on the tab to expand it out, it is empty even though I have text in misc info for the contact. Any suggestions?
11 years 3 months ago #3653 by admin
Replied by admin on topic Misc Information Not Showing Text
it seems like you are having problems with the Joomla contact component itself, the Trombinoscope component does not handle the contact page with the tabs. This is a problem with your template, most likely. Check if you do not have any javascript error on your page.
