exclamation-circle import function wont work
12 years 6 months ago #3306 by ChristianNielsen
import function wont work was created by ChristianNielsen
I've been trying to import an csv-file and have followed your instruction. After the import i get's an message that the import is completed, but nothing is importet.
My CSV contains the following columns
name;email_to;con_position;telephone;catid;published
12 years 6 months ago - 12 years 6 months ago #3307 by admin
Replied by admin on topic Re: import function wont work
can you send a sample of your file at [email protected] so I can test it out?
Another user had trouble with import because it seems like Mac Office does not create the same CSV files the way the Windows version does. I don't know if that is your case.
Make also sure that when opening the csv file as text you have each record on a separate line.
Last edit: 12 years 6 months ago by admin.
