map-pin 403 no permission on stylemaster.css.php
12 years 7 months ago #1640 by admin
Replied by admin on topic 403 no permission on stylemaster.css.php
another user had the same issue the same day you did (what are the odds of that?) and reported today:
Inserting the following 2 lines in section 'allow direct access to the following files' or something similar (translated from German) - into the htaccesss-maker solved the problem:
modules/mod_latestnewsenhancedextended/stylemaster.css.php
modules/mod_latestnewsenhancedextended/animationmaster.js.php
If you don’t know the exact files to be allowed by Admin Tools, you can insert the parent path of the extension in the section 'allow direct access to the following folders (incl. .php files)'. But that’s not as secure.
Thank you Kai!
Just for other users to know and until I come up with a solution that will avoid this extra work with my components.
12 years 7 months ago #1641 by Tetzo
You are welcome. ;)
Regards
-Kai-
12 years 7 months ago #1642 by kehelle
Replied by kehelle on topic Re: 403 no permission on stylemaster.css.php
Thanks for the help! I added the style files under file exceptions in the htaccess maker in Admin tools and it works.
