file No Contact Found
12 years 8 months ago #1483 by johnswaney
No Contact Found was created by johnswaney
I have installed the component. I have a menu item with the Trombinoscope Extended View selected. I have the category set to Administration. In the Component > Contacts, I have two contacts assigned to the Administration category.
When the page loads, it says:
Warning
No Contact Found
Page in question: www.icslima.org/youversity/index.php/abo...culty/administration
Thanks for the help
12 years 8 months ago #1485 by admin
Replied by admin on topic Re: No Contact Found
I do not have enough information to understand what is going on. Can you send me a screenshot of your basic parameters?
When you get this warning, it means that no contact fulfills the database query. So there is probably something that prevents the contacts to be shown.
12 years 8 months ago #1486 by johnswaney
Replied by johnswaney on topic Re: No Contact Found
It may be easier if I give you superuser credents... May I do this?
12 years 8 months ago #1487 by admin
Yes, please send them to [email protected].
