file INSERT INFORMATION IN CARD
12 years 10 months ago #1184 by Musso
INSERT INFORMATION IN CARD was created by Musso
i HAVE DOWNLOADED THE MODULE, I HAVE INSTALLED IT BUT I NEVER UNDERSTAND WHERE I HAVE TO GO FOR PUT THE INFORMATION ABOUT THE CONCTACT (NAME, MOBILE, WEB SITE.ETC.)IN THE CARD AND IN WICH WAY SHO IT IN THE SITE. tANKS FOR HELP ME
12 years 10 months ago #1190 by admin
Replied by admin on topic Re: INSERT INFORMATION IN CARD
the information for the contacts must be set up in the contact's component coming with the Joomla! core. Set categories and then your contacts there. Trombinoscope Extended does not do that, it only uses the information found in the contact component.
I would suggest you download the full documentation for the component, all the information is there to help you in setting the cards the way you want (with a menu item or a module). For instance, to show the email of a contact, set 'email' in one of the fields (1 thru 7).
Thank you for using Trombinoscope Extended!
Don't hesitate to get back to me.
