file Is there an option for accordion style drop down on "More Info"
3 years 11 months ago #5548 by [email protected]
I saw on your demo site:
demo3.simplifyyourweb.com/trombinoscope-extended/business
That the "More Information" goes to a separate page, is there a way to provide an accordion style drop down that contains the text and stay on the same page.
Thanks in advance,
Eric
3 years 11 months ago #5549 by syw
Hello Eric,
the 'more information' is a link to the contact page.
The cards in the directory are no meant for a large amount of information, which is what the contact view is for.
I suppose you could try and create a specific layout for the contact detail you want to show as an accordion.
For creating custom layouts, there is some info here: simplifyyourweb.com/documentation/trombi...om-information-types).
This will be tricky because accordions need some specific markup and multiple accordions on a same page may not work well together and will definitely 'bloat' the directory...
In other terms, I would not advise to use accordions in contact cards.
3 years 11 months ago #5550 by [email protected]
Olivier,
Thanks as always for the response and suggestions.
Eric
