file Modal styling question
4 years 19 hours ago - 4 years 10 hours ago #5538 by rbuelund
Modal styling question was created by rbuelund
I would like to do some styling on the Trombinoscope details popup, but I cannot get anything to work? How do I style the content of the iframe ?? I have tried to add css under general settings Layout pane - but it does not have any effect. You can see the page here: haderslev-jaegerforening.dk.linux205.cur...dk/index.php/kontakt - I want the text to be white, and no border around the image.
Last edit: 4 years 10 hours ago by syw.
4 years 10 hours ago #5539 by syw
Replied by syw on topic Modal styling question
I can see that you found out how to fix your styling, at least for the time being :-)
Any content that opens in a modal in Joomla needs to be styled at the template level. In each template, index.php is the page used for any page on a website, component.php is the page used for 'lone' content, content that is shown without the template framework, like in modals.
Then, when you want to style a Trombinoscope Contact inside a modal, the particular settings are the ones you can find in the global configuration of the extension, particularly in the layout and theming tabs.
