file pagination/animation formatting issue
10 years 11 months ago #3791 by [email protected]
i'm getting a weird formatting issue only when activating pagination/animation.
i saw someone else post this problem with no fix.
can you help? i just purchased extended version.
thank you,
[email protected]
10 years 11 months ago #3793 by admin
Replied by admin on topic pagination/animation formatting issue
this is probably just a problem of configuration.
I will take a look with the credentials you provided.
10 years 11 months ago #3795 by admin
It seems like you have fixed your issues... Let me know.
10 years 11 months ago #3797 by [email protected]
yes thank you.
for anyone else with the issue .. i downloaded the scroll animation and was able to show more than 1 item - also need to set width/height
10 years 11 months ago #3799 by admin
Yes, correct, thanks for the feedback.
Note that you can find that information in the documentation under the 'configurations' section.
10 years 11 months ago #3801 by [email protected]
yes this information is in the documentation .. but a bit hard to understand if you were trying to list multiple items. maybe update the documentation to include a note for multiple item modules that the user wants to use the slide animation to say that the only way to do this is to download the scroll animation.
thank you for your great support
