file Contagts in 2 Colums are not responsive
8 months 4 days ago #6149 by FDE68
Hi, i set up the module and could set up all as wanted ... also set the width of the map to 50% - resulting in two columns.
Fine so far - but there is no breakpoint to switch into just one columns in smartphone view ...
Is there a setting?
Is i a bug or a feature?
Responsitivity is not included?
What to set or any help in what to set in css would be helpful.
Thank you and best regards
FDE
8 months 4 days ago #6150 by syw
Replied by syw on topic Contagts in 2 Colums are not responsive
Hello FDE,
could you send me a link to that page?
This is surely a configuration issue, but I need to see the page to understand the situation. I think you are talking about the contact page but I am not sure as you are also talking about module configuration.
8 months 4 days ago #6152 by FDE68
Replied by FDE68 on topic Contagts in 2 Colums are not responsive
Hello, thank you very much.
Here is the link
dev.pwg1956.de/ueber-uns/ansprechpartner
Best regards
Frank
8 months 4 days ago #6153 by syw
Ok, this is easy :-)
You need to tell the module when the cards go from landscape to portrait mode.
Go to the 'picture' tab and look for the 'Orientation switch width'.
Try different values to see what works best for you. The value is the cut off that decides at which point the picture stops showing on the left but goes on top instead.
8 months 4 days ago #6154 by FDE68
Hello, thanks for- i can see the effect But this is not rhetorical solution.
As on desktop two contacts are next to each other (picture on left) my idea is ths standard responsive - on smartphone just one column (also picture left).
Is that possible?
How to?
Thanks a lot
Best
FDE
8 months 4 days ago #6155 by syw
You have to see values in cards max width and min width to get a fluid layout. The width percentage is not enough.
