file Disable in pages
10 years 1 month ago #4337 by crash3903
Disable in pages was created by crash3903
Good morning
I have tried to disable the plugin in certain pages but it is still loading??
For example I have this page (under development) - Sorry it is protected with access level but hopefully you can give me an idea how to exclude the page
www.pierceandco.co.uk/bt/index.php/account/ticket-overview
Mark
10 years 1 month ago #4342 by admin
Replied by admin on topic Disable in pages
Hi Mark,
can you tell me:
- what extension you are using: the free or the commercial one?
- what values you have put in the 'disable in pages' field?
10 years 1 month ago #4343 by crash3903
Replied by crash3903 on topic Disable in pages
Hi Olivier
Thanks for coming back so quick
I am using the commercial version and I have put the following in the disable section
*ticket*
This refers to my support system (Freestyle Support) which asked for your plugin to be installed
Regards
Mark
10 years 1 month ago #4346 by admin
You are welcome Mark! Thanks for your answers.
I suspect you created a module instance (a profile).
If your ticket system is accessed through a menu item, why not uncheck that menu item from the 'menu assignments' tab of the module in order to disable the jQuery Easy functionality in those pages? It will be more efficient than the 'disable' option which requires extra processing work.
10 years 1 month ago #4347 by crash3903
that's sorted it!
Thanks very much
Regards
Mark
10 years 1 month ago #4348 by admin
Wonderful!
You are welcome :-)
