file plugin interfering with template
10 years 10 months ago #4269 by mikebl
plugin interfering with template was created by mikebl
website is goldinvest.ca
since activating the plugin the transparency of the background (first column where menu is located) is not loading correctly.
also imageshow on homepage isn't loading either - returns an error.
appreciate any help,
thanks,
mike
10 years 10 months ago #4270 by admin
Replied by admin on topic plugin interfering with template
Hello Mike,
I can see that you disabled the jQuery Easy plugin.
In order to understand what is going on, I would suggest you enable it and turn 'on' the reporting tool to get an idea of what has been done by the plugin. This is the easiest way to find out if the plugin has removed important scripts that should be loaded still after cleanup.
I can see some unconventional ways jQuery is loaded on the site (jsn_uf_jquery_safe.js for instance - which probably has to be removed manually in the plugin) and that Bootstrap 2 and 3 are loaded (which may result in erratic behaviors).
Let me know once you have enabled the plugin and get back to me. Thank you!
10 years 10 months ago #4271 by mikebl
Replied by mikebl on topic plugin interfering with template
it's now activated.
where is the file jsn_uf_jquery_safe.js located ?
10 years 10 months ago #4272 by admin
Ok, I will take a look in a minute.
That file is located in the code source of your page :-)
10 years 10 months ago #4273 by admin
Apparently the plugin is not enabled (or you enabled it but did not enable jQuery and selected its version, as well as Migrate).
The plugin's reporting does not seem to be activated either (in the 'other' tab, set 'show report' to 'yes').
10 years 10 months ago #4278 by mikebl
i have done what you asked.
- jquery + US is enabled
- jquery migrate is empty says
"jQuery Migrate helps migrate older jQuery code to jQuery v1.9+. Download and install this plugin locally if needed"
