file Slideshow still missing
12 years 1 month ago #2589 by michellezum
Slideshow still missing was created by michellezum
I've installed the jQuery Easy plugin and enabled it to load jQuery, but the front page slideshow is still missing. (Slideshow CK)
I've messed with the jQuery settings of the slideshow and Virtuemart, but nothing changes.
I'm kinda new to this, so I apologize if I've missed something obvious.
www.buconsulting.com
Any thoughts?
Michelle
12 years 1 month ago #2590 by admin
Replied by admin on topic Re: Slideshow still missing
Hi Michelle,
try to remove the option 'add no conflict code' in the plugin's advanced settings to 'no'. Your other scripts already have everything they need embedded.
Let me know if that helps.
12 years 1 month ago #2606 by michellezum
Replied by michellezum on topic Re: Slideshow still missing
Set "Add No Conflict Code" to No, but still no change.
Michelle
12 years 1 month ago #2608 by admin
There are errors but I cannot seem to find what generates them ($j(...).slides is not a function for instance), which is why there is no slideshow.
Have you tried and contacted the developers of the slideshow?
12 years 1 month ago #2609 by admin
Can you tell me what were the issues BEFORE installing jQUery Easy? That would help me understand.
12 years 1 month ago #2612 by michellezum
The slideshow was working a week ago. I'm not sure what changed. The client may have changed something.
I did contact the slideshow developers and they told me to install this plugin. :P
Maybe I should just try to find a slider that doesn't use jQuery.
