lightbulb-o I have problems with JQuery Easy
13 years 7 months ago #10 by Turin
I have problems with JQuery Easy was created by Turin
Hello.. :woohoo:
I installed the Easy jQuery plugin and I do not work properly ... I have the module VTEM RSS Fed and is not displayed and is or is not because this happens ... if I turn off all my work properly ... if anyone knows I have to do is thank you ... I'm learning not schedule ... thanks :angry:
13 years 7 months ago - 13 years 7 months ago #13 by admin
Replied by admin on topic Re: I have problems with JQuery Easy
If you have selected jQuery UI 1.8.16, please update the jQuery Easy plugin as the latest version is now 1.8.17. The links to jQuery UI 1.8.16 are not valid anymore.
If this does not resolve your issue, please give me the URL to your website so I can take a look.
You can send me an email directly to [email protected].
Last edit: 13 years 7 months ago by admin.
13 years 7 months ago #16 by Turin
Replied by Turin on topic Re: I have problems with JQuery Easy
Thank you very much for responding
I've updated the JQuery Plugin Easy and did not correct the problem remained the same ... let me on the right side VTEM Module RSS Feed and you will see not see anything ... if I deactivate the plugin if I work
this is the image that should be ...
[attachment:1]sin JQuerry Easy.png[/attachment]
13 years 7 months ago #17 by Turin
Sorry ... I miss the link my site is www.bouchot.net :blush: :blush:
13 years 7 months ago - 13 years 7 months ago #19 by admin
As I look at it, the jQuery Easy plugin is not enabled. You have lots of conflicts on your page, several different versions of jQuery are loaded. Can you enable the plugin? Thanks.
13 years 7 months ago #21 by Turin
I have enabled, had enabled a jQuery plugin called CS because I need to work You Bumpit, and this is also the reason why I need a JQuery ... thanks for all the help
