file LNE Basic (not pro): Not displaying columns; only rows?
4 years 4 weeks ago #5627 by djcaptpln880
Hello
I have been using latest news enhanced on my in-development website to make sure its what i need.
I use rockettheme horizon theme in joomla latest 3.9.+ with gantry 5
I aam having problems:
When configuring LNE it allows me to change from row to column
However it will not show columns but will show rows
When I goto layout and try to change it from rows to columns it changes in the back end but won't reflect that in the front end.
I mean Instead of having articles displayed in row format I need to display in column format, side by side.
Any ideas?
4 years 3 weeks ago - 4 years 3 weeks ago #5628 by syw
There are 2 settings that are important when showing items in columns (layout tab):
- the layout needs to be set as 'columns'
- the item width may need to be set at something larger than 50%
Adjust item sizes with min and max widths.
Hope this helps!
Last edit: 4 years 3 weeks ago by syw.
4 years 3 weeks ago #5629 by djcaptpln880
Hello
I have tried all of that! Its very bizarre to me!
I even tried what you suggested!
It still shows up in 1 column!
ANy idea? COuld it be somethign else?
4 years 3 weeks ago #5631 by syw
Ok, now you got me confused... Do you want column, or do you want row? You asked for both :-)
In any case, if you don't see any difference in the front end, this is a cache issue, which you can find answers here:
simplifyyourweb.com/documentation/tutori...-no-matter-what-i-do
3 years 11 months ago #5663 by djcaptpln880
Hello
I just got the forum membership for assistance :-)
My issue still stands.
You can view at the bottom of wellnessbachelor dot com and see that its not displaying in ROWS, only COLUMNS.
Some weeks ago it DID display as rows out of NOWHERE.
Its like it decides to show it when it "feels " like it.
I should let you know I also run under cloudflare, but I even disabled that as well, and it still doesnt function as it should.
ANy ideas?
3 years 11 months ago #5664 by djcaptpln880
I think I may have fixed it:
i loaded with private window and it shows in rows
I had to set max width of the item to 100 px not percent. Very bizarre to me.
Any ideas? :-)
