question-circle Installed fine. Nothing appears.
12 years 10 hours ago #3172 by slowbox
Installed fine. Nothing appears. was created by slowbox
I simply cannot get this module to display on my 3.0 site. :)
Installed both the external syw_lib and the module just fine.
No error messages in the configurations (everything shows compatible).
I've assigned the module to the Position needed on homepage.
Configured basic settings to display the few Featured articles I have.
Show Title enabled, Show Errors enabled, JQuery 1.8 set to Local...
I've read through the documentations---It appears like this would be very easy to get running. Is there a common cause for this module to prevent it from displaying anything?
Currently testing at: cetest.cloudaccess.net (the blank space to the left of the calendar is where the module is assigned).
Any tips appreciated, thanks
12 years 10 hours ago #3175 by admin
Replied by admin on topic Re: Installed fine. Nothing appears.
can you specify on which page the module should show? There is no calendar on the home page (tried to go to activity calendar but I get a 404 error).
Also: you do not need jQuery, it is installed by the template already.
One thing: did you publish the module (easy to miss that one)? Did you assign menus to it?
The module will not show if no articles are found.
12 years 9 hours ago #3176 by slowbox
Replied by slowbox on topic Re: Installed fine. Nothing appears.
Hey, sorry i just disabled the calendar (Along with anything else I could think of that might possibly conflict).
Just the homepage:
It's assigned and published to the position left of the calendar. I had been running the default Latest News module there, but thought yours looked much better.
Not sure what else to try... I read another post someone was also having problems with the T3 framework and/or Mega menu that I'm currently using. However there was no fix mentioned, not sure if its related.
Any thots?
12 years 9 hours ago #3177 by admin
Indeed, the module does not show and there is no sign of any file (like stylesheet) coming from the module.
Could you post screenshots of the settings you use? Module details, basic options and menu assignments? Thanks.
12 years 9 hours ago #3178 by slowbox
Zipped and attached... just went through each tab of the module settings + a screenshot of template layout/positioning.
I've got to leave work now however, so I'll have to respond further tomorrow. Thanks
12 years 9 hours ago #3180 by admin
wow... this framework is complex...
The problem seems to come from menu assignments. Could you try assigning the module to all menu items? You should still see the module's title, even if there is no article.
Other than that, I have noticed you need to unselect 'all categories' in the categories basic option of the module.
Have you tried the latest news module in the same spot?
