file Problem with icons
10 years 10 months ago #3852 by chocovo
Problem with icons was created by chocovo
In config, when I choose to show icon (<i class="icon SYWicon-earth"></i>), css style is applied but it only show a little square with E6OD.
.SYWicon-earth:before {content: "";}
Some help with it?
Best regards
10 years 10 months ago #3853 by admin
Replied by admin on topic Problem with icons
are you using the beta version of the component? Do you have any URL I can check out? Thank you!
10 years 10 months ago #3854 by admin
And I forgot: which browser are you using?
10 years 10 months ago #3862 by chocovo
Replied by chocovo on topic Problem with icons
YES it is beta version. Is it better I use the other version?
My browser is the last Firefox version.
The site is "Under Construction" and it is not online.
Best regards
10 years 10 months ago #3865 by admin
No problem using the beta version, it is just not completely 'prime-time'-ready. But most of the functionality is there. I am flushing out the last bugs.
Can you show a screenshot of the problem?
I have tested icons under all browsers without issues and on several sites.
Do you have this issue for all icons or just the 'earth' one? Are you using the latest version of syw_lib, the external library required for the component (separate install)?
Thank you for your answers.
10 years 10 months ago #3871 by chocovo
The version of syw_lib is:
/** @var  string  Release version. */
	static $RELEASE = '1.1.0';
	/** @var  string  Release date. */
	static $RELDATE = '19-Sep-2014';
The problem is with all my browsers (now using firefox 33.0.3).
Thank you and best regards
