file Fatal Error
12 years 1 month ago #3543 by nbholt
Fatal Error was created by nbholt
Fatal error: Class 'SYWUtilities' not found in /home/pace25ad/public_html/components/com_trombinoscopeextended/views/trombinoscopeextended/view.html.php on line 23
This is what I see when I click on my link. My developers have had a look and apparently we are missing a library or something? help please!!
12 years 1 month ago #3544 by admin
Replied by admin on topic Fatal Error
yes, you are missing a library. There is a warning on the site and when you install the component about it.
Just go to www.simplifyyourweb.com/index.php/downlo...ategory/23-libraries and download the library.
That should fix your issues.
The following user(s) said Thank You: nbholt
12 years 1 month ago #3545 by nbholt
Replied by nbholt on topic Fatal Error
Thank you! I have downloaded and installed. Now I am getting the following error:
Fatal error: Class 'JHelperTags' not found in /home/pace25ad/public_html/components/com_trombinoscopeextended/models/trombinoscopeextended.php on line 807
Is this component related?
12 years 1 month ago #3547 by admin
Can you tell me what version of Joomla! you are using?
JHelperTags is a Joomla! helper class.
11 years 8 months ago #3733 by welsh
Replied by welsh on topic Fatal Error
I am getting the same issue, a white screen with the following error message:
Fatal error: Class 'JHelperTags' not found in /httpdocs/components/com_trombinoscopeextended/models/trombinoscopeextended.php on line 808
I am using Joomla! 2.5.23 Stable
Thanks in advance for your reply
11 years 8 months ago #3734 by admin
This error usually happens when a menu item or module have been created BEFORE installing the syw_lib library.
What needs to be done is to re-save the menu item(s) or the module instance(s) once the library has been installed.
The proper parameters will be saved at this point and remove the error.
