exclamation-circle Issues
11 years 10 months ago #3337 by cbangal
Issues was created by cbangal
Dear Olivier,
Today I bought Timboscopee Entended to my website www.omga.org.au and implemented. But unfortunately the SEARCH
button on the menu does not show up search field and further when I click the SEARCH BUTTON I can see the contact list but no details.
- As per manual it is Timboscopeview but in menu item it only shows up Timboscope
- In the categories only "Sample-data-contact is available.
Please advise.
Regards
Chandra
11 years 10 months ago #3339 by admin
Replied by admin on topic Re: Issues
Hello Chandra,
the search field packaged in Joomla! will give you a standard page of results. That is: a list of contacts, as provided by the search contact plugin.
If you want a search leading to the Trombinoscope view of your contacts, please try the version 1.5 beta. It adds a search field tailored to the component ('show name search' option in the 'contact information' tab).
For the manual, 'Trombinoscope' and 'Trombinoscope view' is the same thing. I have just forgotten to replace the screenshot to reflect the change. Good catch!
For more categories, you need to create categories in the standard Joomla contact component.
11 years 10 months ago #3340 by cbangal
Replied by cbangal on topic Re: Issues
Hi Oliver,
Thanks for your quick response. As per you advise I have downloaded version 1.5 beta(com_trombinoscopeextended_beta.zip) and installed in my site.
Unfortunately in the Menu item type - Trombinscopeview is not available .
Please advise.
11 years 10 months ago #3341 by admin
'Trombinoscope' and 'Trombinoscope View' are the same things. The wording will be corrected for the next release so there is no confusion.
11 years 10 months ago #3343 by cbangal
Hi Olivier,
Thanks for your quick response. Here we go attached screen shots with explanation of issue.
Please advise.
File Attachment:
File Name: Trombinsco...ssue.pdf
File Size:162 KB
11 years 10 months ago - 11 years 10 months ago #3344 by admin
Like I explained :-)
Just use 'Trombinoscope'.
Thanks for the screenshot.
Last edit: 11 years 10 months ago by admin.
